by: blend3r
#47975
Hello
I tried to install Moyave 10.14.4 according to the instructions from https://vanilla.amd-osx.сom
I did everything as it was said there, but the installation stops at the Apple logo, after which the computer restarts. I attach a screenshot. What could be the problem?
My PC:
AMD FX-8300
RX 470
ASUS M5A97 LE R2.0
RAM 10GB
First you should post what guide you followed if a[…]
when boot EFI windows bootloader(bootmgfw.efi) rea[…]
Parallels?
I tried and had problems with Parallels too. OSX […]
you just need RealtekRTL8111.kext for lan to work
