by: 2b_
#46219
Hi,
I have an audio stutter problem, that only occurs on USB audio devices, like:
- USB Bluetooth dongle > Bose Bluetooth headset connected
- USB Bose audio set
- Cheap chinese USB Soundcard
I'll try to describe the stuttering problem: When i play audio on Spotify the sound is OK, no distortion. But for every 3 seconds of playback it seems to be muted for 100 ms. So i get a stuttering effect on the music.
All of this does not happen when headphone with 3.5mm jack is connected to green port of the mobo.
I think AppleALC is installed correctly since Audio settings correctly shows all posible audio output devices.
My hardware:
Ryzen 2700X
32G Trident RGB
ASUS X470 Prime Pro mobo
RX 580 GPU
Installed kexts:
WhateverGreen.kext
VoodooTSCSync.kext
USBInjectAll.kext
SmallTreeIntel82576.kext
NullCPUPowerManagement.kext
Lilu.kext
FakeSMC.kext
AppleALC.kext
AmdCPUMonitor.kext
AHCI_3rdParty_SATA.kext
My config.plist:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>ACPI</key>
	<dict>
		<key>DSDT</key>
		<dict>
			<key>Fixes</key>
			<dict>
				<key>DeleteUnused</key>
				<true/>
				<key>FixHPET</key>
				<true/>
				<key>FixIPIC</key>
				<true/>
				<key>FixRTC</key>
				<true/>
				<key>FixShutdown</key>
				<true/>
				<key>FixTMR</key>
				<true/>
			</dict>
			<key>Patches</key>
			<array>
				<dict>
					<key>Comment</key>
					<string>change SAT0 to SATA</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					U0FUMA==
					</data>
					<key>Replace</key>
					<data>
					U0FUQQ==
					</data>
				</dict>
			</array>
		</dict>
		<key>FixHeaders</key>
		<true/>
	</dict>
	<key>Boot</key>
	<dict>
		<key>Arguments</key>
		<string>-v npci=0x3000 keepsyms=1 debug=0x100 alcid=1 busratio=37</string>
	</dict>
	<key>CPU</key>
	<dict>
		<key>BusSpeedkHz</key>
		<integer>102500</integer>
		<key>FrequencyMHz</key>
		<integer>4100</integer>
		<key>Latency</key>
		<string>0x3E9</string>
		<key>Type</key>
		<string>0x0604</string>
	</dict>
	<key>Devices</key>
	<dict>
		<key>Audio</key>
		<dict>
			<key>ResetHDA</key>
			<true/>
		</dict>
		<key>USB</key>
		<dict>
			<key>FixOwnership</key>
			<true/>
		</dict>
	</dict>
	<key>GUI</key>
	<dict>
		<key>Scan</key>
		<dict>
			<key>Entries</key>
			<true/>
			<key>Tool</key>
			<true/>
		</dict>
	</dict>
	<key>Graphics</key>
	<dict>
		<key>RadeonDeInit</key>
		<false/>
	</dict>
	<key>KernelAndKextPatches</key>
	<dict>
		<key>AppleRTC</key>
		<false/>
		<key>KernelLapic</key>
		<false/>
		<key>KernelPm</key>
		<false/>
		<key>KextsToPatch</key>
		<array>
			<dict>
				<key>Comment</key>
				<string>External Icons Patch</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				RXh0ZXJuYWw=
				</data>
				<key>InfoPlistPatch</key>
				<false/>
				<key>Name</key>
				<string>AppleAHCIPort</string>
				<key>Replace</key>
				<data>
				SW50ZXJuYWw=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>Port limit increase (Rehabman)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g32IDw+DpwQAAA==
				</data>
				<false/>
				<key>MatchOS</key>
				<string>10.13.x</string>
				<key>Name</key>
				<string>com.apple.driver.usb.AppleUSBXHCI</string>
				<key>Replace</key>
				<data>
				g32ID5CQkJCQkA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey USB patch for ryzen</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				xwAAAEGD/QI=
				</data>
				<false/>
				<key>Name</key>
				<string>AppleUSBXHCI</string>
				<key>Replace</key>
				<data>
				xwAAAEGD/RE=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>disable port limit in XHCI kext (credit DalianSky,Ricky)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/sPD4OPBAAA
				</data>
				<false/>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g/sPkJCQkJCQ
				</data>
			</dict>
		</array>
	</dict>
	<key>RtVariables</key>
	<dict>
		<key>BooterConfig</key>
		<string>0x28</string>
		<key>CsrActiveConfig</key>
		<string>0x3E7</string>
		<key>ROM</key>
		<string>UseMacAddr0</string>
	</dict>
	<key>SMBIOS</key>
	<dict>
		<key>BiosReleaseDate</key>
		<string>09/17/2018</string>
		<key>BiosVendor</key>
		<string>Apple Inc.</string>
		<key>BiosVersion</key>
		<string>IM142.88Z.0131.B00.1809171347</string>
		<key>Board-ID</key>
		<string>Mac-27ADBB7B4CEE8E61</string>
		<key>BoardManufacturer</key>
		<key>BoardSerialNumber</key>
		<string>D25332270GUF8YLUE</string>
		<key>BoardType</key>
		<integer>10</integer>
		<key>BoardVersion</key>
		<string>1.0</string>
		<key>ChassisAssetTag</key>
		<string>iMac-Aluminum</string>
		<key>ChassisManufacturer</key>
		<key>ChassisType</key>
		<string>0x0D</string>
		<key>EfiVersion</key>
		<string>133.0.0.0.0</string>
		<key>Family</key>
		<string>iMac</string>
		<key>FirmwareFeatures</key>
		<string>0xE00FE137</string>
		<key>FirmwareFeaturesMask</key>
		<string>0xFF1FFF3F</string>
		<key>LocationInChassis</key>
		<string>Part Component</string>
		<key>Manufacturer</key>
		<key>Mobile</key>
		<false/>
		<key>PlatformFeature</key>
		<string>0x01</string>
		<key>ProductName</key>
		<string>iMac14,2</string>
		<key>SerialNumber</key>
		<string>D25L6HZBF8JC</string>
		<key>SmUUID</key>
		<string>68F09DF6-2B38-4C05-B9F0-61CA592286B6</string>
		<key>Version</key>
	</dict>
	<key>SystemParameters</key>
	<dict>
		<key>CustomUUID</key>
		<string>11D721D4-8311-48DF-9040-DCB5F173448E</string>
		<key>InjectKexts</key>
		<string>Yes</string>
	</dict>
</dict>
</plist>
by: zoomos
#47118
I have the same issue, my stuttering happens during all sound play unless I move the mouse really fast or if I put a load on the CPU like QuickTime screen capture.
I hope I can find a fix, everything seems to be working otherwise.
by: fandrless
#47121
@zoomos, i have some problem too
#47122
Disable Core Performance Boost in the BIOS.
System: Mojave 10.14.4 Motherboard: Gigabyte Aoru[…]
how did you get the bluetooth and wifi working? it[…]
stuck at root device UUID is....
amd 1700 msi b350 rx590 can use this config.pli[…]
Thanks! I'll try it later!
