#46198
Thank you for the reply.
I updated the bios because that bios has a new AGESA .
After I found that I can't enter 10.14.1 Mojave, I tried to downgrade the bios but the bios flasher didn't allow older bios to overwrite the bios.
I couldn't find the way to force to write the old bios to ROM through googling.
I found the solution from another forum. DSDT.aml was the cause of kernel panic. After deletion of DSDT.aml, everything is fine.
#46225
Sounds like my problem after bios update
viewtopic.php?p=46208#p46208
MSI X470 Gaming Plus change log:
- Improve memory compatibility.
- Improve compatibility with Bristol CPU.
ASUS X470 Pro change log:
- Update AGESA 0070 for the upcoming processors and improve some CPU compatibility.
Looks quite similar
Mojave Vega 56 OpenGL
Hey there, i'm currently setting up a hackintosh a[…]
meals meals, and fat, it is likely that insufficie[…]
Mate, I got that booting issue +++++++++++ fixed[…]
You have to start by locating a humdrum Boost Ener[…]
