by: Mahmoud Mostafa
#45509
hello,
i have Ryzen 5 2400G but i don't have external GPU can i setup Mojave ? or i must have any external GPU ?
i will use Xcode only
by: TotallyNotNero
#45512
I know friends who are working on iGPU support in Mojave. To my understanding so far, you can’t use the internal graphics for now. I’m sorry.
If all you are doing is Xcode, you might want to use a Virtual Machine, but then there will be the lack of Graphics Acceleration.
If you want to use a Hackintosh, you can buy an NVIDIA GeForce GT 710, which does work OOB (Out of Box), and is around $30-50 USD.
I hope this helps :)
by: Mahmoud Mostafa
#45515
Thank you bro , i will buy one :thumbup:
TotallyNotNero wrote:I know friends who are working on iGPU support in Mojave. To my understanding so far, you can’t use the internal graphics for now. I’m sorry.
can i use GT 630 ?
I got the same problem, look forward to fixing it […]
Hardware: Processor: AMD FX 8300 Graphics Card: […]
Can you help me? In my installation it gives still[…]
Hi everyone, Ok so I've "almost" instal[…]
