by: bcliu430
#45502
Hi all,
Edited:
still needs help on HDMI sound! Many thanks.
Spec:
MotherBoard: Asus TUF B450-plus
CPU: Ryzen5 2600
HardDisk: Crucial MX100
RAM: CORSAIR Vengeance RGB DRAM 16GB
GPU: ASUS ROG Strix Radeon RX 570 O4G
Edit:
This is what I see and what the spec shows, also I do not have any sound devices, i have lilu and applealc up-to-date
Update 2.13:
On-board sound works with voodooHDA.kext. Working with hdmi/dp sound.
Update 2.14:
Weird screen is solved by changing the hdmi-dvi cord to dvi-dvi cord.
hello everyone, I'm about to buy this motherboard:[…]
i have almost same pc. except gpu. i have rx 460.[…]
As the subject shows, i want to get some games fro[…]
ok thanks for advice, can't go to InsanelyMac I've[…]
