by: danielosx
#45459
Hi
Would like to know if anyone has successfully used Apple Watch to unlock your Mac.
I am running Mojave 10.14.1 and have native support wifi+BT card BCM94360CS2 bought from amazon, also AW4 with latest watchOS.
Have checked the wifi page in "About this Mac" > "System Report" >"Wifi", the "Auto Unlock" is supported.
However "Unlock with Apple Watch" never appears in the "Security and Privacy" page.
I am not sure if this is a problem due to AMD build, because I have saw people using Intel build report Apple Watch Auto Unlock working correctly in other forum.
Appreciate first.
Thanks a lot.
by: Valamyr
#45521
Hi,
It as never worked for me as well since I run macOS on AMD CPU.
Cheers
danielosx liked this
by: danielosx
#45568
Valamyr wrote:
Thu Feb 14, 2019 10:12 am
Hi,
Cheers
okay I see, thanks a lot
Can just be the AMD issue.
Cheers
bcliu430 wrote:
Thu Feb 14, 2019 5:28 pm
BT just works without any modification?
For me, yes. BCM94360CS2 has native support on macOS
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
