#45387
I use this installer and guide viewtopic.php?f=24&t=5902
Mojave installer restart during installation at 2 minutes remaining in the first installation method, installing on HDD with APFS file system.
I not found solution, any idea? My configuration in the signature.
#45558
Hey guys.
I have been banging my head against the wall for over a week trying to get Mojave installed, and I've finally done it. I used Shanee's Vanilla Install Tutorial, and had the same problem with the installer rebooting at two minutes, and the installer would hang at 12 minutes.
My solution – disconnect all other drives. I have a few USB and SATA drives in my build, and I disconnected them all except for the USB thumbdrive to install from and my Windows SATA drive to build it from.
Good luck!
#45571
So if I disconnect keyboard mause and HD that I'm not using will it work?
Does this have to be at the time of the creation of the installation pendrive or can it be at the moment of boot?
I tried two weeks and got stuck in the 12-minute lock, so I gave up on the process.
#45574
Disconnect any drives not necessary for the install (You’ll need your mouse and keyboard). Consider this, mac computers are so integrated/closed, they don’t come with more than one internal drive usually. I have four SATA drives and was trying to install on an M.2 SSD through a USB drive. The installer probably knew something was up. I assume it would only matter when you’re installing/booting, not creating the installer.
#45881
Always restart. I disconnected all sata drives and all usb except mouse, but restart during 2 minutes.
This is the error after restart: Failed to send exception EXC_CORPSE_NOTIFY. Error code: 5 for pid 206
i'm using this installer but after verbose boot mo[…]
nice. details on the ram ? https://www.microc[…]
Inject this kext, https://files.amd-osx.com/XLNCUS[…]
Hi All, First time long time haha, CPU: R7 1700 […]
