by: AstonJ
#44841
Hi
I've read both High Sierra and Mojave guides.
I've created using CreateInstallMedia the Mojave installer, changed prelinked and installed Clover and Clover on my USB
I have some doubts:
What are best set up for Clover config and where to save the config file?
Do I need to run the preinstall command from Terminal also on Mojave install?
After PostInstall do I have to put Efi folder into the boot disk?
by: defexnicolas
#45177
Are you using Mac or Windows to make the UBS installer?
mount you EFI partition,
Oper Clover , here put your config.plis
ViralRX Male Enhancement Is it genuine that you […]
Keto T911. It is a shocking thing that the present[…]
keto KC3000 forskolin fitness apps are discussed h[…]
можно ли человека назвать носителем информации htt[…]
