by: portrayer
#50290
I installed 10.13.6(17G7024) and everything works well except my GTX1060 gpu.
webdriver loaded successfully (version 387.10.10.10.40.128 and up to date), and the resolution is right. but when I use iina to play video, it is very laggy. also, chrome renders web page and images slowly. :crazy:
hackintool shows vda decoder failed.
does anyone meet this problem?
my build is:
CPU: Ryzen 3700X
MB: MSI B450I Gaming Plus AC
GPU: Nvidia GTX1060 6G
RAM: 16G DDR4
WIFI/BT: DW1820A
by: inyourgroove
#50298
I didn't run hackintool but I am seeing the same behavior. I have in the past used this exact GPU on a intel based build without issue. Could it be that we should downgrade to an older driver version?
by: portrayer
#50404
I tried old version 378.10.10.10.25.106 but no luck. Perhaps vda depends intel, sad
You'll get it recognised with full resolution bu[…]
Hi, i'm Julien from France and i'm a newcomer on r[…]
Got to the install screen where disk utility and i[…]
Hey, looking forward to seeing this link to the mo[…]
