by: tuancuong92
#47385
I have a problem that I can use only one DP of my radeon. Anyone have experience about Radeon dual/multi monitor pls help me.
#47390
Are you using Lilu and Whatevergreen? Set the FBConfig to Orinoco in Clover.
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
