by: artizan
#46209
Sorry all but I’m extremely new to the hackintosh scene and I’m only experiencing one problem which is my Wifi card isnt compatible with MacOS. Im currently still booting into High Sierra 10.13.3 via the install usb. I followed this tutorial exactly viewtopic.php?f=24&t=4127 and I have the latest versions of AirportBrcmFixup and Lilu kext files ready however when i tried to install them I got a “does printf work” so I just reinstalled high sierra and working again. I found that on a reddit post somebody was asking about this problem and another user posted the githubs of these two kexts, are these the right kexts I need for my situation and if not where could I find them? Any help is greatly appreciated
System: Mojave 10.14.4 Motherboard: Gigabyte Aoru[…]
how did you get the bluetooth and wifi working? it[…]
stuck at root device UUID is....
amd 1700 msi b350 rx590 can use this config.pli[…]
Thanks! I'll try it later!
