by: pharic
#45480
Hi mates :thumbup:
This is my first attempt to get a hackintosh working so sorry If I don't know about some things. First of all I did a Mojave Hackintosh with Shanee tutorial (viewtopic.php?f=24&t=5902) but I had to get rid of It because I realised that nvidia web drivers wasn't available, so I used Norton287 tutorial (viewtopic.php?f=24&t=4127) in order to make a High Sierra Hackintosh.
Boots ok, graphics are working perfectly fine, but my ethernet is not working properly. Sometimes It works as well as in windows, but the most of times when I turn on the computer connection is not working or working too slowly. Everytimes my ethernet port show as connected on the panel control, but I have to reset the pc like 3 or 4 times to get it working well. I have installed the latest Realtek RTL811 kext (v2.2.2) and deleted other ethernel kexts, but that's not working too. In the first attempt, with Mojave, my ethernet was working perfectly without any kext or something.
Can u help me a little bit? :)
Specs:
MSI B350M Bazooka
Ryzen 5 1400 3,20 GHz
RAM 8 GB DDR4 3200MHz
Kingston 240GB SSD
1050TI Asus Cerberus edition
Thanks!!
hello everyone, I'm about to buy this motherboard:[…]
i have almost same pc. except gpu. i have rx 460.[…]
As the subject shows, i want to get some games fro[…]
ok thanks for advice, can't go to InsanelyMac I've[…]
