by: Trevor30
#45362
My OS version: macOS 10.13.6
GPU: Geforce GTX 660
CPU: AMD Athlon x4 750K
Motherboard: Gigabyte GA-F2A88XM-D3H
Kext in the CLOVER/EFI/kext/Other folder: Lilu, Whatevergreen (latest)
And this is the problem, and attached my config.plist
https://imgur.com/6nPW4Dx
Any solution?
Here is the terminal result, after running sudo kextcache -i / command
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f015170 [0x7fff91b6eaf0]> { URL = "BSDKernel.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.bsd" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f0161f0 [0x7fff91b6eaf0]> { URL = "Libkern.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.libkern" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f017640 [0x7fff91b6eaf0]> { URL = "Mach.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.mach" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f012830 [0x7fff91b6eaf0]> { URL = "IOKit.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.iokit" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f01ab10 [0x7fff91b6eaf0]> { URL = "Private.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.private" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f0198e0 [0x7fff91b6eaf0]> { URL = "Unsupported.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.unsupported" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f018870 [0x7fff91b6eaf0]> { URL = "MACFramework.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.dsep" }
Kext with invalid signatured (-67054) allowed: <OSKext 0x7f823f2567f0 [0x7fff91b6eaf0]> { URL = "IONetworkingFamily.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.iokit.IONetworkingFamily" }
Kext with invalid signatured (-67030) allowed: <OSKext 0x7f823f1bd580 [0x7fff91b6eaf0]> { URL = "DummyUSBEHCIPCI.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.driver.usb.AppleUSBEHCIPCI" }
DummyUSBEHCIPCI.kext - no compatible dependency found for com.apple.driver.usb.AppleUSBEHCI.
DummyUSBEHCIPCI.kext - no compatible dependency found for com.apple.iokit.IOUSBHostFamily.
DummyUSBEHCIPCI.kext is missing dependencies (including anyway; dependencies may be available from elsewhere)
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823cc44470 [0x7fff91b6eaf0]> { URL = "GenericUSBXHCI.kext/ -- file:///System/Library/Extensions/", ID = "net.osx86.kexts.GenericUSBXHCI" }
Kext rejected due to improper filesystem permissions: <OSKext 0x7f823f025970 [0x7fff91b6eaf0]> { URL = "WhateverGreen.kext/ -- file:///System/Library/Extensions/", ID = "as.vit9696.WhateverGreen" }
WhateverGreen.kext does not authenticate; omitting.
Kext with invalid signatured (-67030) allowed: <OSKext 0x7f823f021ed0 [0x7fff91b6eaf0]> { URL = "DummyUSBXHCIPCI.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.driver.usb.AppleUSBXHCIPCI" }
DummyUSBXHCIPCI.kext - no compatible dependency found for com.apple.iokit.IOUSBHostFamily.
DummyUSBXHCIPCI.kext - no compatible dependency found for com.apple.driver.usb.AppleUSBXHCI.
DummyUSBXHCIPCI.kext is missing dependencies (including anyway; dependencies may be available from elsewhere)
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f01bee0 [0x7fff91b6eaf0]> { URL = "AppleNMI.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.driver.AppleNMI" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f019080 [0x7fff91b6eaf0]> { URL = "IONVRAMFamily.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.IONVRAMFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f017160 [0x7fff91b6eaf0]> { URL = "IOSystemManagement.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.IOSystemManagementFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f0143b0 [0x7fff91b6eaf0]> { URL = "ApplePlatformFamily.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.ApplePlatformFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f0132d0 [0x7fff91b6eaf0]> { URL = "Kasan.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.kasan" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f823f010350 [0x7fff91b6eaf0]> { URL = "System.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.kernel" }
Kext rejected due to improper filesystem permissions: <OSKext 0x7f823cd17700 [0x7fff91b6eaf0]> { URL = "Lilu.kext/ -- file:///System/Library/Extensions/", ID = "as.vit9696.Lilu" }
Lilu.kext does not authenticate; omitting.
KernelCache ID: 90AB9C27E3342DEA0EB85C0BC1B542DB
Kext rejected due to improper filesystem permissions: <OSKext 0x7fd91073e4b0 [0x7fff91b6eaf0]> { URL = "Lilu.kext/ -- file:///System/Library/Extensions/", ID = "as.vit9696.Lilu" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e3200 [0x7fff91b6eaf0]> { URL = "System.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.kernel" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e56e0 [0x7fff91b6eaf0]> { URL = "IOKit.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.iokit" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e6180 [0x7fff91b6eaf0]> { URL = "Kasan.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.kasan" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e7260 [0x7fff91b6eaf0]> { URL = "ApplePlatformFamily.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.ApplePlatformFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e8020 [0x7fff91b6eaf0]> { URL = "BSDKernel.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.bsd" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128e90a0 [0x7fff91b6eaf0]> { URL = "Libkern.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.libkern" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128ea010 [0x7fff91b6eaf0]> { URL = "IOSystemManagement.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.IOSystemManagementFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128ea4f0 [0x7fff91b6eaf0]> { URL = "Mach.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.mach" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128eb720 [0x7fff91b6eaf0]> { URL = "MACFramework.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.dsep" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128ebf30 [0x7fff91b6eaf0]> { URL = "IONVRAMFamily.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.iokit.IONVRAMFamily" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128ec790 [0x7fff91b6eaf0]> { URL = "Unsupported.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.unsupported" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128ed9c0 [0x7fff91b6eaf0]> { URL = "Private.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.kpi.private" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd9128eed90 [0x7fff91b6eaf0]> { URL = "AppleNMI.kext/ -- file:///System/Library/Extensions/System.kext/PlugIns/", ID = "com.apple.driver.AppleNMI" }
Kext with invalid signatured (-67030) allowed: <OSKext 0x7fd912901640 [0x7fff91b6eaf0]> { URL = "DummyUSBXHCIPCI.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.driver.usb.AppleUSBXHCIPCI" }
Kext rejected due to improper filesystem permissions: <OSKext 0x7fd912903b00 [0x7fff91b6eaf0]> { URL = "WhateverGreen.kext/ -- file:///System/Library/Extensions/", ID = "as.vit9696.WhateverGreen" }
Kext with invalid signatured (-67062) allowed: <OSKext 0x7fd912aac610 [0x7fff91b6eaf0]> { URL = "GenericUSBXHCI.kext/ -- file:///System/Library/Extensions/", ID = "net.osx86.kexts.GenericUSBXHCI" }
Kext with invalid signatured (-67054) allowed: <OSKext 0x7fd912b254f0 [0x7fff91b6eaf0]> { URL = "IONetworkingFamily.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.iokit.IONetworkingFamily" }
Kext with invalid signatured (-67030) allowed: <OSKext 0x7fd912de6760 [0x7fff91b6eaf0]> { URL = "DummyUSBEHCIPCI.kext/ -- file:///System/Library/Extensions/", ID = "com.apple.driver.usb.AppleUSBEHCIPCI" }
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
