#45178
Got as far as upgrading to 10.13.6 with working nvidia web-drivers and installing a few bits of software.
After installing either kaspersky or ovpn clients the computer will suddenly re-boot without warning.
Clearly they are changing some system files you have modified. Any Idea's ?
Long time FreeBSD user so happy with command line.
X399 Taichi 3.50 bios
1900x Threadripper
GTX 1070
32GB Team 3200 mem
Update 1: Second install completely vanilla, nothing extra installed, followed upgrade guide to the letter and after about 4/5 minutes sudden re-boot. Booted back into 10.13.3 backup and runs ok. Time to search thro logs and try to figure it out.
Rebooting into 10.13.6 after upgrade and opening up a terminal and running
sudo kextcache -i / && sudo kextcache -u /
Fixed the problem
#46231
hello menditsa, after running the kextcache fix -- you're now able to use your vpn clients?
i'm currently on 1.13.3 and:
- when i use openconnect -- terminating that (ctrl+c) will instantly reboot my computer
- or, if i install cisco anyconnect -- osx will attempt to boot up -- but will get stuck in a reboot loop. (i wasn't able to boot in safe mode... nor did booting from clover on usb helped -- i had to reinstall from the beginning again...)
i'd love to see i can get to 1.13.6 to see if this would fix this issue -- but most of the build instructions says to "DO NOT UPGRADE (from 1.13.3)"... =)
thanks in advanced!
System: Mojave 10.14.4 Motherboard: Gigabyte Aoru[…]
how did you get the bluetooth and wifi working? it[…]
stuck at root device UUID is....
amd 1700 msi b350 rx590 can use this config.pli[…]
Thanks! I'll try it later!
