by: Deleted User 46610
#44343
Hello new here,
mobile post sorry for format.
So i have been dealing with the issue as seen in the title basically it only shows the cursor on a grey screen where the post-install setup should be. Anybody that can help me?
Installer used from here High Sierra v3
System specs:
CPU: A8-7650k
Mobo: Asrock FM2A68M-HD+
4GB RAM
GPU: on its way, just ordered it
EDIT: Fixed it by reinstall
#44775
hello. I have the same computer configuration as you.Have you installed successfully?
#44782
jincabbage wrote:hello. I have the same computer configuration as you.Have you installed successfully?
Hi made new account, Yes I’ve actually managed install it on there but got no acceleration on that APU so you need a dedicated GPU if you got one and have the same motherboard in the BIOS set the Primary VGA to Auto other it will detect multiple video cards in Clover and hang at boot
Success. :D
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
https://fitose.com/keto-fuel/
In these days of supersizing, buffets, and large d[…]
I have same cpu, any tips appreciated. Firm inte[…]
