#38420
Hi,
I just installed V2 and updated it to the latest version of macOS. Clover, while installed, on any settings refused to boot with a message before the verbose messages.
AMF: Only 248/256 slide values are usable! Booting may Fail! Valid Slides: 8-255 and the computer would shut down after 20 seconds. it would boot to macOS via usb. So to fix the problem I merged the CLOVER folder from the EFI on the USB and the EFI folder on the SSD. That didn't work either.
And, with Clover configured to use HDMI audio and FixShutdown, the computer would stay at before the verbose messages at the message before the '*********************'.
Any help on solving this issue would be greatly appreciated.
PC Specs:
ASUS A88XM-E (Original USB 3.0, Latest BIOS)
AMD A8-6600K CPU
AMD Radeon R9 380 Series (Clover detects it as a R9 250 but it still works)
16GB 1877MHz DDR3 RAM
128GB Kingston SSDNow SSD (macOS)
256GB SanDisk Ultra 3D SSD (Windows)
1TB Seagate Barracuda (Storage)
#38436
Don't merge the USB EFI just replace the EFI on your SSD before making any changes and see if it boots. Then make changes to config.plist one by one with a reboot in between to see whats causing it to hang.
#38470
Hi, Thanks for the response. I have done what you have said but the Clover bootloader hangs at the line OsxAptioFixDrv: Starting overrides for \System\Library\CoreServices\boot.efi
Using reloc block: yes, hibernate wake : No
without the line of asterisks underneath.
#38487
And you can boot off the installer ok?
#38491
Yep. Using the inject ati config and -PCIRootUID=0. When booted off the usb, there is no hdmi audio output and no acpi. And when I tried a config from Clover Configurator with custom settings to the USB bootloader, the USB bootloader hangs at the exact stage the bootloader copied to my SSD from the USB.
#38508
post your config.plist and I'll take a look at it.
#38511
AFAIK, the config file is the same from the USB Installer bootloader. But i'll still attach it. (I use config_InjectATI.plist)
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>ACPI</key>
	<dict>
		<key>DSDT</key>
		<dict>
			<key>Fixes</key>
			<dict>
				<key>FixDisplay</key>
				<true/>
				<key>FixShutdown</key>
				<true/>
			</dict>
			<key>Name</key>
			<string>DSDT.aml</string>
		</dict>
		<key>HaltEnabler</key>
		<true/>
	</dict>
	<key>Boot</key>
	<dict>
		<key>Arguments</key>
		<string>-v npci=0x2000</string>
		<key>DefaultLoader</key>
		<string>boot.efi</string>
		<key>DefaultVolume</key>
		<string>LastBootedVolume</string>
		<key>Legacy</key>
		<string>PBR</string>
		<key>NeverHibernate</key>
		<true/>
	</dict>
	<key>Devices</key>
	<dict>
		<key>Audio</key>
		<dict>
			<key>Inject</key>
			<string>Detect</string>
			<key>ResetHDA</key>
			<true/>
		</dict>
		<key>ForceHPET</key>
		<true/>
		<key>USB</key>
		<dict>
			<key>AddClockID</key>
			<true/>
			<key>FixOwnership</key>
			<true/>
			<key>Inject</key>
			<false/>
		</dict>
	</dict>
	<key>GUI</key>
	<dict>
		<key>Language</key>
		<string>en:0</string>
		<key>Theme</key>
		<string>Lightness</string>
	</dict>
	<key>Graphics</key>
	<dict>
		<key>Inject</key>
		<dict>
			<key>ATI</key>
			<true/>
			<key>NVidia</key>
			<false/>
		</dict>
	</dict>
	<key>KernelAndKextPatches</key>
	<dict>
		<key>AppleRTC</key>
		<true/>
		<key>KextsToPatch</key>
		<array>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#1</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<string>IONVMeFamily</string>
				<key>Find</key>
				<data>weAMBQAQAACJgw==</data>
				<key>Replace</key>
				<data>weAJBQAQAACJgw==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#2</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>D7aMiIIAAACD+QwPhTIBAA==</data>
				<key>Replace</key>
				<data>D7aMiIIAAACD+QkPhTIBAA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#3</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>AMeDpAAAAAAQAABIi0gISA==</data>
				<key>Replace</key>
				<data>AMeDpAAAAAACAABIi0gISA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#4</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>SYnGTYX2dGFBwecMSWP/vg==</data>
				<key>Replace</key>
				<data>SYnGTYX2dGFBwecJSWP/vg==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#5</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>hv8PAABIwegMD7cPgeH/Dw==</data>
				<key>Replace</key>
				<data>hv8PAABIwegJD7cPgeH/Dw==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#6_7</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>icGB4f8PAABIAdFIgfn/DwAAdzs=</data>
				<key>Replace</key>
				<data>icGB4f8BAABIAdFIgfn/AQAAdzs=</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#8</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>SYHF/w8AAEnB7QxJiwQkSA==</data>
				<key>Replace</key>
				<data>SYHF/w8AAEnB7QlJiwQkSA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#9_10</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>BgIAAEyNuAAQAABMiflIgeEA8P//SYmGGgEAAEmJjiIBAABBvAAQAABJKfQ=</data>
				<key>Replace</key>
				<data>BgIAAEyNuAACAABMiflIgeEA8P//SYmGGgEAAEmJjiIBAABBvAACAABJKfQ=</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#11</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>AABJiY4iAQAAugAQAABIKQ==</data>
				<key>Replace</key>
				<data>AABJiY4iAQAAugACAABIKQ==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#12</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>yAAAAEkp17gAEAAATYskJA==</data>
				<key>Replace</key>
				<data>yAAAAEkp17gAAgAATYskJA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#13</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>4b+AQBUGTYnWugAQAABFMQ==</data>
				<key>Replace</key>
				<data>4b+AQBUGTYnWugACAABFMQ==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#14</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>iWTY+EmBxAAQAABJgccA8A==</data>
				<key>Replace</key>
				<data>iWTY+EmBxAACAABJgccA8A==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#15</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>Bf8PAABIwegMZvfB/w8PlQ==</data>
				<key>Replace</key>
				<data>Bf8PAABIwegJZvfB/w8PlQ==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#16</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>weIIQQ+2wcHgDEQJ0EQJwA==</data>
				<key>Replace</key>
				<data>weIIQQ+2wcHgCUQJ0EQJwA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>IONVMeFamily Pike R. Alpha Patch#17</string>
				<key>Disabled</key>
				<false/>
				<key>Name</key>
				<key>Find</key>
				<data>RYTJD5XAD7bAweAMRAnYRA==</data>
				<key>Replace</key>
				<data>RYTJD5XAD7bAweAJRAnYRA==</data>
			</dict>
		</array>
	</dict>
	<key>RtVariables</key>
	<dict>
		<key>BooterConfig</key>
		<string>0x28</string>
		<key>CsrActiveConfig</key>
		<string>0x67</string>
		<key>MLB</key>
		<string>XA0480HFC295I</string>
		<key>ROM</key>
		<data>
		YIrp////
		</data>
	</dict>
	<key>SMBIOS</key>
	<dict>
		<key>BiosReleaseDate</key>
		<string>08/08/17</string>
		<key>BiosVendor</key>
		<string>Apple Inc.</string>
		<key>BiosVersion</key>
		<string>MP51.88Z.0084.B00.1708080528</string>
		<key>Board-ID</key>
		<string>Mac-F221BEC8</string>
		<key>BoardManufacturer</key>
		<key>BoardSerialNumber</key>
		<key>BoardType</key>
		<integer>11</integer>
		<key>BoardVersion</key>
		<string>1.2</string>
		<key>ChassisAssetTag</key>
		<string>Pro-Enclosure</string>
		<key>ChassisManufacturer</key>
		<key>ChassisType</key>
		<string>0x07</string>
		<key>Family</key>
		<string>MacPro</string>
		<key>FirmwareFeatures</key>
		<string>0xE80FE136</string>
		<key>FirmwareFeaturesMask</key>
		<string>0xFF1FFF3F</string>
		<key>LocationInChassis</key>
		<string>Part Component</string>
		<key>Manufacturer</key>
		<key>Mobile</key>
		<false/>
		<key>PlatformFeature</key>
		<string>0xFFFF</string>
		<key>ProductName</key>
		<string>MacPro5,1</string>
		<key>SerialNumber</key>
		<string>XA0494P0HFC</string>
		<key>Version</key>
	</dict>
	<key>SystemParameters</key>
	<dict>
		<key>CustomUUID</key>
		<string>31433142-3044-3743-4539-4143FFFFFFFF</string>
		<key>InjectKexts</key>
		<string>Yes</string>
		<key>InjectSystemID</key>
		<true/>
	</dict>
</dict>
</plist>
#38662
I was having the same problem and I got mine working by changing npci=0x2000 to npci=0x3000. Try it out and lemme know.
#38686
It's hard for me to fully test it out since we have different specs, but I'll try my best.
Just as an update and based on a previous comment, is it hanging up on the USB bootloader AND the SSD?
Also, did you update macOS to 10.13.3 or did you keep it at 10.13.2?
Happy Holidays
Merry Christmas and happy new year Shanee and tha[…]
Can you help me ? What step did you take pre-insta[…]
Did you even try to run the script.. Because DSDT […]
Hello everyone. Today i tried to update my amdint[…]
AMD OS X Advertisements
