by: giallux92
#37325
Hello guys,
I've managed to install high sierra v2 and everything seems to work fine.
I only have one problem: I had a fresh Windows 10 (with EFI partition of 300mb) install before going with High Sierra, updated it and then went on with Mac. Now that I've Clover EFI installed, clover boot can't boot Windows 10, I just have a black screen for 5 seconds then it goes back to clover boot . What can I do to fix it without having to reinstall win10 again?
Doesn't work.. I added my config.plist to pastebin[…]
Hey guys ! I updated from High Sierra (10.13.6) to[…]
Having same issue with my build
After I update to high sierra 10.13.6 i install […]
