by: RandomTrollface
#36463
Hi all! I'm just getting in to this hackintosh stuff but after following the ryzen guide from hackintosher I managed to get nearly everything working. The only thing I still can't get to work is audio. When I try to use my HyperX cloud 2 usb headset in macOS the audio just stutters every 1-2 seconds or so, after like 15 seconds the audio stops working completely. I'm using the latest VoodooHDA in /EFI/CLOVER/kexts/Other. My motherboard (asus b350 prime plus) uses the realtek alc 887 codec which voodooHDA should support right?
My system:
Ryzen [email protected] (I've already set the busratio)
1050ti with webdrivers installed
Asus b350 prime plus
(I'm posting from my windows drive because macOS crashes once in a while)
Hey, I gived up last time with that setup but now […]
Thank You! This method definitely makes docker us[…]
This post ^ 100% working. Thank you mate, I final[…]
How can i do upgrade from highsierra 10.13.3 to 10[…]
AMD OS X Advertisements
