#51840
Hi. I'm running 3900x with GTX1080 and I experience poor performance in some applications such as iTerm2 or Sublime Text. Youtube videos (1440p60fps) in Opera browser or launchpad are running completely fine, whilst ie iTerm is shattering on printing text. Not to mention resizing windows. Same goes with Sublime Text. it's just a text editor and opening a file takes.. well too much. Scrolling in a tiny file is shattering too.
I noticed, however, that if I resize iTerm to be, say, 1/4 size of my screen (single monitor, 1440p res), it'll work fine but as I increase window size it gets worse and worse. iTerm and Sublime are using hardware acceleration but I can't say to what extent. Enabling/disabling it doesn't make any difference.
I don't even know which part or driver to investigate because GPU seems to be coping fine with heavy tasks but the observed performance degradation when increasing window size somehow suggest it actually is graphics related? I don't know..
It's a simple fix. Open your network kext and edit[…]
Hi gm0rk, I have the same mainboard as you, an AS[…]
Use this modified RTL8111 for LAN, https://www.d[…]
alright i'll do that thanks Post Merged hello […]
