by: javierish
#48288
Hi! I Have been trying to install High Sierra to my SSD. I am using the XLNC installer version 2.5. I configured the bios as close as I can to the tutorials I have seen and I was able to boot the OS X installer from my USB and formatted my SSD. The problem happens when I start installing High Sierra to my SSD. It stops at the 11 minute mark . I left it alone but it stayed that way for 5 hours. Any help would be appreciated -
CPU - AMD A10-7870k
MOBO - EMAXX EMX-A70FM2+iCafe
GPU - Geforce GT 730
SSD- WD Green 240 GB
RAM- 8 GB DDR 3
Hi, that sounds great. You've decided to install H[…]
Hi, I'm not sure but seems to me like your install[…]
Hi, you'd better tell us how do you prepare your b[…]
Hi, did you put your new config.plist and kexts in[…]
