by: Jxa
#48069
I'm currently trying to install software via .iso files soft mounted into OSX 10.13.6 . There seems to be an issue with them recognizing the calls to the mounted images. I've gotten "no information to install" errors as well as installs that will complete anything local to their packages, but nothing that requests information from the loaded images.
An example would be VMFusion, when creating a new VM and selecting an image, it closes the procedure and pulls up the VM instance window with a play icon immediately. Clicking on the icon renders an "Internal Error" popup as the OS was never actually installed on the VM.
Specs again Ryzen 5 2600 OSX 10.13.6 (was also an issue on 10.13.3)
Any help would be appreciated.
Ok So, I swapped out the Virtual SMC Kext for the […]
We don't support that method of installing. Use th[…]
Stuck at Random Seed
I could not boot 10.14.6 installer. Had the same p[…]
Crash at installation screen
Hey guys! So I've been having problem installing A[…]
