by: namednad
#47940
I'm a newbie and I have been attempting to create a boot disk using Shaneee's post - HIGH SIERRA AMD VANILLA GUIDE FROM WINDOWS. I am having issues with Bootdisk utility which I downloaded from one of the links in that post. I als found a version of Bootdisk Utility from 2016 and it also gives me the same error message when I attempt to check Clover. Everytime I attempt to check for Clover update with either version I get a message, "Error sending the HTTP request to the server". I don't know why this happens, I assume I don't have something configured correctly. I have downloaded fresh copies of the zip file and re-installed a couple of times with no change from this Error message each time I try to check Clover.
Also when the USB Clover partition is created it has no files in it. Is this normal?
Any help with this would be appreciated very much. I thank you in advance for any help you might be able to offer.
Respectfully,
dan
First you should post what guide you followed if a[…]
when boot EFI windows bootloader(bootmgfw.efi) rea[…]
Parallels?
I tried and had problems with Parallels too. OSX […]
you just need RealtekRTL8111.kext for lan to work
