by: tigerrrflame
#47409
Hi guys, i have an GA 970a DS3P with FX8320e, 16gb RAM and GTX960 4gb. I saw a video that said i need to add "nv_disable=1" in bootflags if you have an nvidia card. My motherboard dont have Onboard video. My question is: when you put "nv_disable=1" you just disable the drivers or the entire hardware?
Sorry for bad english.
Bump!
First you should post what guide you followed if a[…]
when boot EFI windows bootloader(bootmgfw.efi) rea[…]
Parallels?
I tried and had problems with Parallels too. OSX […]
you just need RealtekRTL8111.kext for lan to work
