by: gaza1994
#46151
Hi,
So - I've been following the "How to install High Sierra Vanilla" guide - had some major issues with my Realtek 8111 LAN - what i ended up having to do was place the files in OSX Base System / System/Library/Extensions for the installer to pick it up and use it!
So, i got the first part of the installer working, the files are sitting nicely on my drive - i rebooted back to the USB, copied over my PreLinkedKernel thing and rebooted again this time to my SSD with OSX on it.
It sat for about 20 minutes until i was greeted with
> considerRebuildOfPrelinkedKernel
> various timeout messages
It sat like that for an hour doing nothing :(
Where have i went wrong? :(
also after that im getting
> kextd stall[0], (240s): 'AppleACPICPU'
Any help would be appreciated :)
by: gaza1994
#46212
hi yes - i ended up using their discord to get my hackintosh working!!
All i done was replace virtualSMC.kext with FakeSMC.kext and i was able to boot no problem
Mojave Vega 56 OpenGL
Hey there, i'm currently setting up a hackintosh a[…]
meals meals, and fat, it is likely that insufficie[…]
Mate, I got that booting issue +++++++++++ fixed[…]
You have to start by locating a humdrum Boost Ener[…]
