by: Viridis
#46141
Had a working install before using the guide off this forum, everything worked as far as connecting to Apple services but decided to do another install this time on a dedicated SSD.
Installed just as before and everything working again except iTunes.
Every time I try to login, it connects to iTunes store and then throws up another login popup, this carries on infinitely.
I'm logged In to iCloud fine, everything there seems ok, just iTunes causing this problem.
Any advice?
Thanks
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
