#46134
Hello!
So you're getting this error?
This version of Mac OS X is not supported on this platform!
Then here's how to fix!
Windows/Linux Guide
(for users that have no access to a Mac)
Spoiler:
Go to http://cloudclovereditor.altervista.org ... overeditor and load your config.plist. (The file is located in EFI/CLOVER/)
Click on SMBIOS on the left, and choose "iMac 14,2" on the dropdown menu.
After that, click on the sidebar at the very top: "Cloud Clover Editor". Then click "Download", save the file and replace the old config.plist file with it.
macOS Guide
Spoiler:
Download Clover Configurator and open the Config.plist file (The file is located in EFI/CLOVER/).
Click on SMBIOS on the left, choose "iMac 14,2" and replace the old config.plist file.
That's it!
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
