by: gamil
#46047
Hello everyone,
I'm trying to get a VM with High Sierra 10.13.6 to work but I'm out of luck here, I've tried many pre-installed images of virtual disks from various sources still couldn't get it to work, except for one with version 10.13.2, yet I cannot reboot the machine, for some reason it keeps getting stuck at "MACH Reboot".
My Host Setup:
HP Compaq Pro 6305 SFF
CPU: AMD A10-5800B APU with Radeon HD Graphics (4CPUs) ~3.8GHz (Compatible with SSE4.1 Instruction Set)
Total RAM: 12GB
GPU: NVIDIA GeForce GT-630 (Dedicated 2GB)
Currently I have another VM with 13.10.6, which I've obtained its image from (techsviewer.com), but it keeps getting stuck at boot screen, precisely at "Start Random Seed", and it never gets past this point.
I'd appreciate any help with getting this VM up and running, or on explaining how to solve this problem, or is this setup incompatible with that version of macOS at all?
Thank you so much <3
For reference, here is my machine "vbox" definition file:
<?xml version="1.0"?>
** DO NOT EDIT THIS FILE.
** If you make changes to this file while any VirtualBox related application
** is running, your changes will be overwritten later, without taking effect.
** Use VBoxManage or the VirtualBox Manager GUI to make changes.
<VirtualBox xmlns="http://www.virtualbox.org/" version="1.17-windows">
  <Machine uuid="{32a6aadb-d708-4c3f-9e6a-49512dc04987}" name="osx13" OSType="MacOS1013_64" snapshotFolder="Snapshots" lastStateChange="2019-03-07T20:39:39Z">
    <MediaRegistry>
      <HardDisks>
        <HardDisk uuid="{5397f31e-9602-4db4-96b8-de1da7bbf9bb}" location="D:/virtual/macOS High Sierra by Techsviewer/macOS High Sierra by Techsviewer.vmdk" format="VMDK" type="Normal"/>
      </HardDisks>
    </MediaRegistry>
    <ExtraData>
      <ExtraDataItem name="GUI/LastCloseAction" value="PowerOff"/>
      <ExtraDataItem name="GUI/LastNormalWindowPosition" value="0,23,640,480,max"/>
      <ExtraDataItem name="VBoxInternal/Devices/efi/0/Config/DmiBoardProduct" value="Iloveapple"/>
      <ExtraDataItem name="VBoxInternal/Devices/efi/0/Config/DmiSystemProduct" value="MacPro6,1"/>
      <ExtraDataItem name="VBoxInternal/Devices/efi/0/Config/DmiSystemVersion" value="1.0"/>
      <ExtraDataItem name="VBoxInternal/Devices/smc/0/Config/DeviceKey" value="ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc"/>
      <ExtraDataItem name="VBoxInternal/Devices/smc/0/Config/GetKeyFromRealSMC" value="1"/>
      <ExtraDataItem name="VBoxInternal2/EfiGopMode" value="3"/>
      <ExtraDataItem name="VBoxInternal2/EfiGraphicsResolution" value="1280x1024"/>
    </ExtraData>
    <Hardware>
      <CPU CpuProfile="Intel Core i7-6700K">
        <PAE enabled="true"/>
        <NestedHWVirt enabled="true"/>
        <LongMode enabled="true"/>
        <HardwareVirtExLargePages enabled="true"/>
        <CpuIdTree>
          <CpuIdLeaf id="1" eax="67301" ebx="1050624" ecx="10019837" edx="3219913727"/>
        </CpuIdTree>
      </CPU>
      <Memory RAMSize="4096"/>
      <Firmware type="EFI"/>
      <HID Pointing="USBTablet" Keyboard="USBKeyboard"/>
      <HPET enabled="true"/>
      <Chipset type="ICH9"/>
      <Boot>
        <Order position="1" device="DVD"/>
        <Order position="2" device="HardDisk"/>
        <Order position="3" device="None"/>
        <Order position="4" device="None"/>
      </Boot>
      <Display VRAMSize="128"/>
      <VideoCapture screens="1" options="ac_enabled=false" file="." fps="25"/>
      <BIOS>
        <IOAPIC enabled="true"/>
      </BIOS>
      <USB>
        <Controllers>
          <Controller name="OHCI" type="OHCI"/>
        </Controllers>
      </USB>
      <Network>
        <Adapter slot="0" enabled="true" MACAddress="0800272600A1" type="82545EM">
          <NAT/>
        </Adapter>
        <Adapter slot="8" cable="false"/>
        <Adapter slot="9" cable="false"/>
        <Adapter slot="10" cable="false"/>
        <Adapter slot="11" cable="false"/>
        <Adapter slot="12" cable="false"/>
        <Adapter slot="13" cable="false"/>
        <Adapter slot="14" cable="false"/>
        <Adapter slot="15" cable="false"/>
        <Adapter slot="16" cable="false"/>
        <Adapter slot="17" cable="false"/>
        <Adapter slot="18" cable="false"/>
        <Adapter slot="19" cable="false"/>
        <Adapter slot="20" cable="false"/>
        <Adapter slot="21" cable="false"/>
        <Adapter slot="22" cable="false"/>
        <Adapter slot="23" cable="false"/>
        <Adapter slot="24" cable="false"/>
        <Adapter slot="25" cable="false"/>
        <Adapter slot="26" cable="false"/>
        <Adapter slot="27" cable="false"/>
        <Adapter slot="28" cable="false"/>
        <Adapter slot="29" cable="false"/>
        <Adapter slot="30" cable="false"/>
        <Adapter slot="31" cable="false"/>
        <Adapter slot="32" cable="false"/>
        <Adapter slot="33" cable="false"/>
        <Adapter slot="34" cable="false"/>
        <Adapter slot="35" cable="false"/>
      </Network>
      <AudioAdapter controller="HDA" driver="DirectSound" enabled="true" enabledIn="true" enabledOut="true"/>
      <RTC localOrUTC="UTC"/>
      <GuestProperties>
        <GuestProperty name="/VirtualBox/HostInfo/GUI/LanguageID" value="en_US" timestamp="1551936562049678500" flags=""/>
      </GuestProperties>
    </Hardware>
    <StorageControllers>
      <StorageController name="SATA" type="AHCI" PortCount="2" useHostIOCache="false" Bootable="true" IDE0MasterEmulationPort="0" IDE0SlaveEmulationPort="1" IDE1MasterEmulationPort="2" IDE1SlaveEmulationPort="3">
        <AttachedDevice type="HardDisk" hotpluggable="false" port="0" device="0">
          <Image uuid="{5397f31e-9602-4db4-96b8-de1da7bbf9bb}"/>
        </AttachedDevice>
        <AttachedDevice passthrough="false" type="DVD" hotpluggable="false" port="1" device="0"/>
      </StorageController>
    </StorageControllers>
  </Machine>
</VirtualBox>
Also here is a screenshot of the boot screen:
https://drive.google.com/open?id=1yeUwT ... -T7Cf6jXqW
After trying on a different machine, I managed to get the VM to work using the latest Mojave version, and I tried to create a working snapshot and try to run that snapshot on my starting machine, the one with (Amd A10) CPU, and it works and reboots without any problems until it reaches the point of "End Random Seed" at the start of booting, which is odd and excuse me if I'm asking noob questions here, but I can't seem to have a properly functioning machine using the original machine and I'm not really sure exactly why.
Anyways, I've tried tot install Clover, but the installation fails every time, even with RehabMan's fork, I've noticed that the directories were created at "/EFI" partition, and I've also tried to add Clover as a boot option, and it just boots into a very large screen with white background and Clover logo, but nothing else.
Please I'm stuck here, and I need to make this work ASAP.
Thank you everyone for your time and attention.
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
