#45981
T6E should work OOB in macOS. Does it show under System Information at all?
by: Furiel
#51746
I have the same problem, when i boot from the USB installer made using Vanilla Mojave tutorial i get: The Recovery Server Could be Contacted
Any hints would be appreciated. Thanks!
It's a simple fix. Open your network kext and edit[…]
Hi gm0rk, I have the same mainboard as you, an AS[…]
Use this modified RTL8111 for LAN, https://www.d[…]
alright i'll do that thanks Post Merged hello […]
