#45481
I installed OSX HS on my inspiron 5675 successfully, but when I go to boot from the usb stick to boot from the OSX partition on my hdd. it boots to "+++++++++++++++" and freezes and also my usb ports are not working, like kb, mouse are dead. However booting the installer from USB is just fine. Is there something I need to copy over from the usb stick to my osx install on my hdd?
Ryzen 1700
16gb ddr4
1tb seagate hdd for osx install
Dell RX580 8gb
X-fi sound card
Stock dell motherboard (not sure what model)
nevermind i dont read things. clicked forum link and found what to do.
stucks at Apple logo
@Shaneee , Lilu and Whatevegreen is UPtodate and[…]
You’ll need a GPU to run macOS on that. See […]
[Fixed] RX580 not booting
I will double check the AHCI support as soon as I […]
My configuation: GPU:Sapphire Vega64 Limited Editi[…]
