#44823
Hi, I already own a Ryzen 7 2700x with an Asus Prime B350M-A: I put the patched AMD kernel by Shanee for 10.13.6, patched IONetworkingFamily.kext and System.kext in an existing High Sierra 10.13.6 Intel installation, my system booted perfectly fine and is really fast.
Using THE SAME disk and kernel, just attaching it to a Gigabyte X399 Aorus Gaming 7 and a Threadripper 2990wx (Bios 11e), i get this:
https://www.dropbox.com/s/6ve236yhp0ub9 ... 5.mp4?dl=0
which is basically this screenshot:
https://www.dropbox.com/s/3v5rqh8olsox8 ... 3.jpg?dl=0
Using cpus=1 flag or npci=0x2000 doesn't make any difference... Even adding VoodooTSCSyncAMD.kext to SLE and recreating the prelinkedkernel cannot change anything... do I need a patched kernel or a DSDT?
If I try an existing Sierra installation that works for my Ryzen I get an Invalid kernel opcode error and a consequent panic in AppleACPIPlatform.kext.
Finally this is what I get using a freshly created installation pen drive with HighSierraV3Unofficial.dmg:
https://www.dropbox.com/s/pvhm7flkzo3zc ... 8.jpg?dl=0
Please give me some hints... do I need perhaps a similar patch? https://osx86.org/forums/topic/20691-ex ... rk/?page=2
DSDT not bootable x399 F10.zip
DSDT bootable Ryzen.zip
It seems that since F10 BIOS osx is not bootable anymore, using a patched dsdt from my Ryzen setup partially works but system cannot show the gui... Can you help me patching x399 aorus dsdt? I'll post the two files right now!
Solved editing CPU's SSDT, read the solution!!! https://www.insanelymac.com/forum/topic ... nt-2659334
Happy AMD Hackintoshing :)
Hello! I'm Erick, and I have been an avid Apple fa[…]
You can disable this option. :thumbup:
Hello how are you today? I have managed to instal[…]
if you compress the file in order to get it from[…]
