#44813
Hi, I have an HP Pavilion notebook with the following features:
-CPU: AMD A8-4555M APU
-RAM: 8 GB
-GPU: AMD Radeon HD 7600G
-HDD: 500GB
I found there are different AMD architectures and different GPU configurations when installing High Sierra. I would like to know if my laptop is compatible, and also know how to install it. I have found several videos but each one makes different configurations for their GPUs. Thanks.
#44824
Sundhar88 wrote:
Thu Jan 10, 2019 11:16 am
Hi!
Your CPU is compatible. But the GPU might not work. Problems with laptops is GPU won't work. You can use hackintosh without Graphic Acceleration. No animations no vibrancy and only 8mb of Graphics memory.
there be any way to make it work or to do it without even doing the installation?
Tp Link Tl-wn823n is USB and works out of the box
Problem at installation reboot
Looks like some files are missing from the install[…]
Help for install
If the disk is not showing up, in the same sceen w[…]
Have you tried injecting Lilu and Whatevergreen in[…]
