#44803
Hey all, So currently I am battling a problem with choppy audio and when I reboot my system it requires a forced power off (basically I get all of the verbose output then the computer never reboots after the screen goes black). I also used the native audio fix for Ryzen CPUs, this helped but didn't fix the problem (side note: the choppy audio is only for system sounds and programs like Spotify. I have no problem running YouTube in Safari). Any help appreciated.
Hello! I'm Erick, and I have been an avid Apple fa[…]
You can disable this option. :thumbup:
Hello how are you today? I have managed to instal[…]
if you compress the file in order to get it from[…]
