by: Seiffear
#44777
My PC:
CPU: AMD FX-8370
MB: MSI 970 Gaming
Ram: 12Gb
HDD for MacOS: Toshiba 320Gb
Video: GTX 1050Ti
In second part installation, after the first boot from HDD, installation is interrupted. Message: macOS could not be installed on your computer. An error occurred installing macOS. To use Apple Diagnostics to check your Mac hardware, shut down, press the power button, and immediately hold the 'D' key until diagnostics begins. Quit the installer to restart your computer and try again.
Log file attached.
Is this a problem with hardware compatibility or is it my mistake?
The problem was solved by disabling another HDD. Everything is established and works fine.
Can't install Mac OS X Sierra Ryzen
Hey. I also have CH6, but the processor is 2700x, […]
How? I have the same problem
I have the same problem of Bensmith please Shane c[…]
so can I also install on the Ryzen 5 2500U? :?:
