#44758
Hello everyone,
I got "Error while trying to synchronize audio and midi" error in Logic Pro X and also having some audio sync issues. I tried to use busratio flag in clover. I use FX6300 CPU and I tried so many bus ratio. 20 and 21 seem the best options, but 20 is too low and 21 is too high for the optimum sample rate.
What should I do else ?
My system information is in the signature.
Thank you very much.
It is a little bit strange, but I solved the problem by adjusting the busratio to 205. I didn't slow down the computer and it seems like it is equivalent to 20.5.
Catalina ??
Sweet!!!!!
Hi Zool, in answer to your question Yes to everyth[…]
Hi man in the suit, I would try using the HDD from[…]
I think I read somewhere that a guy having the sam[…]
