#44114
Hey guys, following shaneee's tutorial I updated my 10.13.3 (V3 Unofficial) to 10.13.6, worked but can't install Xcode 10.1 or Security Update 2018-002, they made my computer freeze and reboot.
So I tried it the other way:
1. Before installing the 10.13.6 combo update, boot into Volume "macOS" and terminal this: sudo nano -W /System/Library/CoreServices/SystemVersion.plist
2. Change both "10.13.3" string into "10.13.6", leave "17D47" alone, no need to change that.
3. Reboot, then install Xcode 10.1, run it and let it finish installing components, if it don't let you run, reboot and retry.
4. Uninstall the web driver, and undo the change in step 2, reboot your computer.
5. Boot into Volume "Clone", install the 10.13.6 combo update and security update 2018-002.
6. follow shaneee's tutorial, replace stuffs, terminal rp, terminal kextcache -i/-u. and if kextcache -i don't work as expected like return some error code, try this:
6.1 Download "Shaneee_10.13.6.zip" from Shaneee's github: https://github.com/Shaneee92/AMD-High-S ... U/releases
6.2 Plugin the USB driver "HighSirraAMD", which is the one used to install 10.13.3 V3 Unofficial.
6.3 Unzip "Shaneee_10.13.6.zip", replace the files with the same names in HighSirraAMD/AMD, remember to make backups. (actually i don't know the files replacing is necessary or not, i did it tho.)
6.4 Reboot and boot into USB HighSirraAMD, ternimal "amd".
7. boot into Volume "macOS", see if it works.
tuancuong92 liked this
#45463
scyllane wrote:
Thu Nov 22, 2018 3:52 am
hi
you didn't mention in which step create Clone partition... and also
after installing 10.13.6 combo update must boot into 10.13.6 HS to install update 2018-02 from Appstore... so i think after install 10.13.6 combo update in step , jump to step 6 is necessary before installing update 2018-02..
am i right?
Thank you very much for this guide. Everything is[…]
:thumbup: Post Merged :clap: Post Merged b[…]
On the off chance that
Trialix I utilized this machine of development, an[…]
Just wondering if the parts I've chosen will work […]
