by: mauimade71
#43352
THese are my specs of my laptop. Am i able to use High Sierra and Final Cut?
Aspire 3 A315-41-R8UU
2GHz AMD Ryzen 5 2500U dual-core processor
15.6" diagonal Full HD display with 1920x1080 resolution
8GB RAM
AMD Radeon Vega 8 graphics
1TB hard drive
#43354
You'd be able to install sure but the integrated Vega GPU won't work under macOS so it's not worth it I'm afraid.
by: Jurze
#43384
Also it seems like Final Cut performs WAY better on intel platforms, so its probibly not worth it performance wise, if at all you could get that gpu working.
by: bernek
#43385
I work in FCP on an iMac 27 2015 i5 R9 380 and I also installed on my Ryzen 5 2600 Hackintosh with RX580 ... it is 5x better and faster on my Hackintosh ...
by: Jurze
#43386
bernek wrote:
Sat Oct 13, 2018 11:22 am
Intel Quick Sync should be way faster for rendering compared to OpenCL!
by: bernek
#43412
@Jurze, I'm working on those iMacs (2015) since they were released and in FCP 8 hours / day thrust me I can spot the difference !
by: Piyush
#44689
@bernek Hey bro I am currently using intel g4560 for my hackintosh and fcpx. Should I get any performance improvement as I upgrade to ryzen 5 1600? For fcpx 😅 I am really concerned about the rendering time.
Hey, I have the same issue, and after posting on […]
Hi, I have the same issue with a Ryzen 2700 and […]
INSTALLATION TO SSD STOPS
Why aren't you using Vanilla method? Maybe try tha[…]
Thank you
