by: cepv2010
#43343
Hi,
I’m new on hackintosh, and actually i installed MacOs HIgh Sierra 10.13.6 but when i’m trying to install xcode components these freeze or restart and i couldn’t install.
What can i do??
by: Leekun
#43646
I have same problem too.. successfully updated from 10.13.3 to 10.13.6 but the installin components phase of xcode installer made my system reboot and after that my computer rebooted every 5 mins...
by: Paytime
#43672
Yup exact same problem here. It's freezing when Xcode is trying to install additional components.
I have an AMD Ryzen 5 1600 CPU, GTX 1060, 16GB Ram (if that info matters)
That really really sucks, because pretty much the only reason I've installed macOS is for Xcode. Looking forward to a fix.
by: yasawijaya
#43720
installing os x on amd sure is complicated.. :crazy:
by: Anulo2
#43722
Paytime wrote:
Mon Oct 29, 2018 6:43 pm
Same hardware and same problem. Hope they will fix
by: BiMode
#43726
i used to do this:
1. install a 10.13.3 system and not update to 10.13.6 yet
2. edit SystemVersion.plist in the CoreService folder and change the version string and version code to 101.3.6's one and dont forget to backup the files and dont restart yet
3. install latest xcode and run it and make sure it install all the required components successfully
4. revert SystemVersion.plist back to previous one and reboot
5. you can install the update to 10.13.6 from now and xcode can be launch successfully without reboot or crash.
Good luck.
For some reason, when extracting the archives of t[…]
Update to 10.13.6 so you can use the updated kerne[…]
Hello after formatting the hard drive I only have […]
There is no timing problems on AMD macos. CPU wi[…]
AMD OS X Advertisements
