by: alekseys92
#41702
Configuration:
Motherboard - Gigabyte 970A DS3P (rev. 2.0)
CPU - FX4300
Ram - 16Gb
Graphics - MSI 1060 (Nvidia)
I use the installer - HighSierraAMD_V2 UEFI. = write TransMac = usb - Ok
Clover (-v npci=0x2000)
Installation is successful and the PC goes to reboot. Further I try to boot from HDD (where I made the installation) using the loader with the same parameters (Clover) as when installing.
I get the following problem:
OsxAptioFix2Drv: Starting overrides for \macOS Install Data\Locked Files\Boot Files\boot.efi
Using reloc block: yes, hibernate wake:no
OsxAptioFix2Drv and OsxAptioFixDrv replaced - no result
Thanks!
The question is settled. pre install and amd. Who is interested in the implementation of this configuration, please contact!
by: AlGrey
#41714
run post install (AMD command).. check the tutorials if you are not sure what you are doing.
by: Ruleman92
#45486
alekseys92 wrote:
Sun Jul 15, 2018 5:31 pm
Configuration:
CPU - FX4300
Ram - 16Gb
Thanks!
Hello! I'm trying to install High Sierra for first time in a Hackintosh pc, but i got the same problem as you.
Can you tell me the solution? Thanks!
Install hackintool and click bootloader tab, selec[…]
External Drive Patch for Ryzen 3000?
Ok, so I'm relatively new to AMD. I'm looking arou[…]
Yeah exactly... I think it's really important for […]
Hey Guys, I followed this guide (https://forum.am[…]
