#40915
Hi guys , i finished install Mac os high sierra and nvidia driver web + cuda driver follow: " HighSierraAMD V3 Unofficial viewtopic.php?f=24&t=4127"
everything work just fine (many thanks admin for that) but the shutdown and restart
after shutdown/restart after some line of code ( i will update later) it turn off the screen but my PC keep running ( the fan and led ) but it won't shutdown/restart and just keep running fan and stuck at that .
please help me , thank you .
#40916
Check the console log for the time you were shutting down, with the console app. It is probably GenericUSBXHCI holding up the restart.
vutung92 liked this
#40936
Norton287 wrote:Check the console log for the time you were shutting down, with the console app. It is probably GenericUSBXHCI holding up the restart.
thank you for reply
this is my screen when i shutdown and system.log
can you help me find it out ?
#40940
Which kernel are you using? From Terminal, do a uname -a, and report that here.
#41033
Norton287 wrote:Which kernel are you using? From Terminal, do a uname -a, and report that here.
here man :thumbup: :thumbup:
High Sierra boot installer problem
Solved, using another tutorial with HighSierraAMD_[…]
NEWBIE
Hi guys, I'm new here and wanted to see if Hacki[…]
I'm not sure if anyone has this problem. I can see[…]
Anyway I can get a link to how you guys achieved t[…]
