by: Booblej
#38581
Hello,
I've been having trouble setting a Clover theme. I installed High Sierra using the AMD installer provided in this site and installed Clover on the boot drive, though Clover didnt have a theme set (and have to press "Enter" to boot the system). I've tried changing the Theme via Clover Configurator, as well as directly modifying the config.plist with no luck. Each time i reboot, it's like i never even set a theme. Quite puzzling, has anyone seen this issue before?
by: XLNC
#38586
Booblej wrote:Hello,
#1 Put the theme folder in EFI/CLOVER/themes/
#2 Open config.plist with CloverConfigurator VE
#3 Go to GUI section and put the theme folder name that you copied in step #1
NOTE: If you are using a 4k monitor then your theme must also support 4k or else it will fall back to default.
by: Booblej
#38594
XLNC wrote:
Fri Mar 02, 2018 8:00 pm
Thanks for replying XLNC :thumbup: I'm familiar with the process of adding & setting themes with Clover, though wasn't sure why it wasn't working for me on the Ryzen build. After reading your reply, i went back in CC to confirm the settings one more time and noticed that i had "Text only" checked in the GUI section. Unticking the checkbox seemed to have done the trick :D Thanks again!
phyxia liked this
by: phyxia
#49736
[/quote]
thanks man, after uncheck "Text Only" now i can see my Theme after couple weeks :crazy:
Having the same issue. Built this hackintosh speci[…]
Thanks so much for the response. I think I will […]
I have the same problem, when i boot from the USB […]
Hi everyone, i have successfully completed my Cata[…]
