by: Jellycakes24
#37749
I was active in the OSx on AMD scene a few months back, but due to frustration I gave up and moved on. But recently from using the family Mac I have been more inclined in getting OSx on my machine. What first steps would you recommend to get myself started up?
Sent from my SM-G930F using Tapatalk
by: Norton287
#37750
AMDHS V2 with enoch bootloader found here: viewtopic.php?f=23&t=2948
by: Jellycakes24
#37830
Norton287 wrote:AMDHS V2 with enoch bootloader found here: http://forum.amd-osx.com/viewtopic.php?f=23&t=2948
what kernel am I using ? The shanee one or bronya?
by: Norton287
#37831
Your choice either is good as far as I'm concerned.
by: Jellycakes24
#37834
Norton287 wrote:Your choice either is good as far as I'm concerned.
How would I work out what usb drivers I need ? Or shall I go with the first one and just try it out ?
by: Norton287
#37835
Go with the first and give it a go, can always go back.
by: Jellycakes24
#37837
Norton287 wrote:Go with the first and give it a go, can always go back.
Getting to the post install, I'm not sure what drivers and so on to install or remove. And is it better to install nvidia drivers and bootloader in the same "xlnc" command?
by: Norton287
#37838
Its best to get them all done before final boot
Following https://forum.amd-osx.com/viewtopic.php?[…]
@Valamyr @Marcyvee It's working on Mojave when &q[…]
hello shanee I am stuck at the first start on the […]
zederex Clearly, this is going to lengthen the[…]
