by: loftzone
#37709
I tried two times with AMD v1 and AMD v2. I stuck at same point.
Screen shots attached.
Could you some one tell me what it could be the reason the boot fail ?
my hardware specs down below.
AMD FX 8350, 4.0 GHZ, 16MB CACHE, 32 NM, AM3+
GIGABYTE 990FXA-UD5 DDR3 1866MHZ S+GL+16X AM3 +
SAPPHIRE HD 7850 OC 2GB 256 BIT GDDR5 16X
KINGSTON HYPERX GENESIS 32 GB RAM.(4X8 GB) 1600 MHZ DDR3
SAMSUNG SSD
by: Norton287
#37712
Is this HighSierraAMD Official or AMD HS?
by: loftzone
#37745
I used "AMDHS_Installer_v2_clover.dmg" this image.
Now, I am downloaded "HighSierraAMD_V3.dmg" and in first step I got "invalid kernel opcode (64-bit) : 4a ..." error, continuesly.
Do you have any suggestion for my hardware ?
by: Norton287
#37747
There's bugs with that install with USB, download V2 from my signature and install then update to 10.13.3 via the app store.
Here's the tutorial for V2 : viewtopic.php?f=24&t=3460
Here's the instructions for upgrading through the app store: viewtopic.php?f=52&t=3950
by: spykor
#37786
Same problem here. I get stuck at (almost exactly) the same point, When I use Bronya's kernel. With Shaneee's kernel I don't even get to that point. Maybe is the kernel (FX) or the mobo (I have 990XA-UD3 as can be seen at my signature).
The strange thing is that I have succesfuly installed all OS Xs from Maverics to Sierra and -with some juggling- made them work properly.
No idea why High SierraAMD wont install (or even boot).
loftzone wrote:
Wed Feb 14, 2018 7:02 pm
I get the exact same error messages from V3 as you do. It has to be some kind of incompatibility between SHaneee's kernel and AMD FX CPU series (or the mobos).
by: loftzone
#37840
Ok. I downloaded HighSierraAMD_V2 UEFI.dmg from your signature, Norton287.
It is freezeed while trying to boot from USB at first step.
Nothing happening.
by: Norton287
#37841
loftzone wrote:Ok. I downloaded HighSierraAMD_V2 UEFI.dmg from your signature, Norton287.
Nothing happening.
It shouldn't hang there unless the image is corrupt. Remake it with transmac and try booting again.
If that doesn't work and you've tried 3 clover installers and not one worked, you can try HighSierraAMD Official V1 with Enoch. Here's the download link:
https://drive.google.com/open?id=1l9GulwYuVK309jN6w8qBC8rDat7LUVnD
by: Loader009
#37894
Norton287 wrote:
Fri Feb 16, 2018 9:33 pm
Nothing happening.
I had the same problem with HighSierraAMD V2 UEFI, I tried to boot via UEFI with USB3.0.
Either try to boot with USB2.0 and/or not with UEFI.
I downloaded the file three times, at the end I can say that this hashes should be correct:
md5
bd9db1df08050612f5ac50efbcd70772 HighSierraAMD_V2 UEFI.dmg
sha256
7b519022e11223641e473a2490e9628cae26e1f4def2ac5a9e8a7850a1729063 HighSierraAMD_V2 UEFI.dmg
BUT; something is broken, I cannot install. See attached picture.
(Same problem with HighSierraAMD_V2.dmg)
edit: HighSierraAMD Official V1 with Enoch.dmg seems to be corrupted too.
(Downloaded twice with the same md5hash: 27b8ecdfdad234c73fa2e46c260efe0c)
dmg2img -v "HighSierraAMD Official V1 with Enoch.dmg" "HighSierraAMD Official V1 with Enoch.img"
dmg2img v1.6.7 (c) vu1tur ([email protected])
ERROR: dmg image is corrupted
I thought it is also a img (though, it is as small as hackintosh dmg images), so I wrote it as an img to my usb drive...
The usb drive has no partition scheme, so it is indeed a dmg.
Please share your images as torrents... this prevents data corruption by the hoster or during transfer.
by: Norton287
#37934
The images aren't corrupt, just today it's been downloaded 88 times with no complaints. Just use transmac to copy them to USB not dmg2img.
Following https://forum.amd-osx.com/viewtopic.php?[…]
@Valamyr @Marcyvee It's working on Mojave when &q[…]
hello shanee I am stuck at the first start on the […]
zederex Clearly, this is going to lengthen the[…]
