by: jpatten
#37697
i boot into amdhighsierra but when i get to the installer my mouse and keyboard dont work :(
by: Norton287
#37718
Are they PS2 or USB?
by: jpatten
#37740
usb.l i havent used ps2 in years
by: Norton287
#37741
Is this during the install or after install?
by: jpatten
#37742
they stop working once i get onto the install screen. they work fine in clover
by: Norton287
#37743
Which installer are you using HighSierraAMD Official V2 or AMDHS
by: jpatten
#37744
i got it off the amd osx website. On windows the file is called HighSierraAMD_V3
by: Norton287
#37746
There's bugs with that install with USB, download V2 from my signature and install then update to 10.13.3 via the app store.
Here's the tutorial for V2 : viewtopic.php?f=24&t=3460
Here's the instructions for upgrading through the app store: viewtopic.php?f=52&t=3950
by: jpatten
#37748
okay thank you :)
can i use my thumb drive with the files needed for post installation that were downloaded with v3?
by: jpatten
#37752
The sources are listed for Mojave here: https://op[…]
I'm using an Asus B450M Tuf gaming plus with a 270[…]
random ketbord freeze
Since when I updated to 10.13.16 I have continuos […]
How to Install ENOCH video)
Struggled forever getting this to work doing it al[…]
AMD OS X Advertisements
