by: FrenchFryKy
#37689
Hi everyone,
I know this may be a stupid question, but I was just curious: is it possible to run macOS fully off a flash drive? I was wondering because I already have Windows installed on my system and wanted to see what I could do without having to wipe Windows off my HDD or get a whole other one.
by: a09hopper
#37690
Yea probably but it would be really slow
Sent from my WAS-LX1A using Tapatalk
by: Norton287
#37721
Just make sure its in a USB 3 port and you should be ok. I ran several versions on an external drive for a while with no problems.
by: Egress
#37780
FrenchFryKy wrote:
Wed Feb 14, 2018 12:46 am
Hi everyone,
Yes. Get the fastest USB Flash Drive you can afford. Sandisk Extreme is quite fast, at least the speed of a good spinning disk. Use USB 3 port only. Usb 2 is really slow.
:thumbup:
by: FrenchFryKy
#37783
Great. Thank you all!
Also ich habe einen amd Fx8300e und eine GTX1060 […]
Shaneee's AMD Build
Not sure I've got an Android phone. Thanks. B[…]
If you are still running the RX 480 and are on 10.[…]
So what's the status of the 10.13.6 update? Are we[…]
AMD OS X Advertisements
