by: s1der
#37528
Hi all,
I'm newbie to hackintosh but I finally managed to install a system that looks stable for the moment.
I would like to use a Terratec PHASE88 PCI sound card. This one is well recognized under Windows but invisible under HighSierra.
Would there be a kext to install or other to enable PCI slots?
Thank you for this forum and thank you for your help!
Cannot finish install hs
I install hs v3 unofficial without any problems, b[…]
I get an error message during installation: "[…]
Can you run applications like Parallels Desktop o[…]
App Store Fix
@chad.. thanks a lot man, now even icloud works.. […]
AMD OS X Advertisements
