- Thu Feb 08, 2018 2:29 am
#37438
So when i went to play my midi piano on logic pro x it would cause the program to crash.
*Fix*
So when you go to create a new instrument select software instrument, then select empty Channel strip.
Works good for me now.
*Fix*
AMD FX-8350 Black Edition Vishera 8-Core 4.0 GHz (4.2 GHz Turbo) Socket AM3+ 125W FD8350FRHKBOX Desktop ...
ASUS M5A97 LE R2.0 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
G.SKILL Ripjaws X Series 20GB (2 x 8GB +4gb) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
Rosewill Hive Series 750W Modular Gaming Power Supply, 80 PLUS Bronze Certified, Single +12V Rail
EVGA GeForce GTX 1050 Ti FTW GAMING ACX 3.0, 04G-P4-6258-KR, 4GB GDDR5, DX12 OSD Support (PXOC)
https://www.paypal.me/Taitmon
