#37263
I got it installed using the AMDHS_Installer v1. I can boot into it from the installer but not from the clover that I installed. The second thing is that it wants to update to 10.13.3 but is always back at 10.13.2. How do I get it to boot correctly and how do I get it to take the update?
I figured it out and everything works now.
by: sjwoolf
#37987
jeremy371980 wrote:I got it installed using the AMDHS_Installer v1. I can boot into it from the installer but not from the clover that I installed. The second thing is that it wants to update to 10.13.3 but is always back at 10.13.2. How do I get it to boot correctly and how do I get it to take the update?
Wait, how did you fix it? I think I'm having the same issue. I finished all the steps through installing the graphics drivers and clover. However, after ejecting the installer USB and rebooting, it just boots back into windows with no option to boot into mac. What did I miss?
Cannot finish install hs
I install hs v3 unofficial without any problems, b[…]
I get an error message during installation: "[…]
Can you run applications like Parallels Desktop o[…]
App Store Fix
@chad.. thanks a lot man, now even icloud works.. […]
AMD OS X Advertisements
