by: krs360
#34286
Hey guys,
So, I've had a little experience with Hackintosh machines over the last few years, mostly intel, however I did get Sierra working on my old FX8150.
I have just purchased a 1950x and the Aorus Gaming 7 board and wondered if anyone had success with this hardware? I used the create installmedia and installed clover, however right after initializing FakeSMC the machine hard locks. I guess it could be missing kexts, etc. If anyone has a guide for this specific hardware or experience with it, I would appreciate any help.
Thanks.
by: Norton287
#34289
Which model of Aorus, the first one that came up was an intel board.
by: Norton287
#34314
Ethernet card is ok, need to run DPCIManager to ID your wifi. M.2 is hit or miss with High Sierra, works for some doesn't for others.
Tutorial: viewtopic.php?f=24&t=3216
Download it from the downloads menu up top.
by: krs360
#34445
Hi there, downloading now and I'm going to give it a shot using that tutorial. I think the wifi is intel based so it's very unlikely to work.
That tutorial says it wont work with nvidia? Not sure what it means by that?
by: Norton287
#34446
Theres a radeon install for clover based bootloader, only need it if you have a radeon card. If you do PM me.
by: Norton287
#34456
No worries :thumbup:
by: krs360
#35742
Hi Norton,
Project got sidetracked for sometime unfortunately, having issues where it would normally present the installer screens at the GIOLockstate message. I assume it's something to do with my 1080TI, unfortunately the only other card I have is a 560TI after a clean out of old hardware.
Do I need to add some kexts to the image or is there another one I should be using?
This is all before getting into the installer GUI btw.
Thanks.
by: Norton287
#35744
You can press space bar when you highlight Boot macOS from HighSierraAMD and arrow down and select nv_disable=1 and then arrow up and choose Boot with these options.
I faced this error: $ sudo sh AMD_audio_cloverAL[…]
Hello, I've managed to install and setup everythi[…]
Unsupported CPU
Thanks I’ll try them. Unfortunately they don[…]
Kernel is based on XNU https://opensource.apple.c[…]
