by: Norton287
#33214
Edimax EQ-7811Un USB Adapter works with accompanying drivers, works on 10.7 through 10.13
#33239
TP-Link N900 Wireless Dual Band PCI-Express Adapter (TL-WDN4800) Works out of the box from 10.9 to 10.13.1. Flawlessly
Egress liked this
by: Artuist
#33846
D-Link DWA-131 rev.B1 works on 10.8 up to 10.13.1 by installing the drivers/software from the link below.
http://files.dlink.com.au/Products/DWA-131/REV_E/Drivers/DWA-131_MacOS10.11_Drivers.zip
If the speed isn't good enough on a USB 2.0 port try a USB 3.0. That did the trick for me.
by: 5fusion
#37707
Norton287 wrote:Edimax EQ-7811Un USB Adapter works with accompanying drivers, works on 10.7 through 10.13
i got this adapter checking this thread. used to work good on HS 10.13.1 but after upgrading to 10.13.3, it just works for the first time when you install the drivers and reboot. But on later boots it doesnt for some weird reason and shows this message (attachment) and the wifi icon keeps flickering.
Egress liked this
#37714
Open System Preferences Network and make sure the adapter is not disabled. Also right click the menu bar icon and make sure its turned on.
by: 5fusion
#37754
Alright the adaptor was plugged in usb 3.1 port. changed it to 3.0 and it started working. thanks
#37755
No problem
by: datdude717
#37820
The NETGEAR Nighthawk AC1900 USB adapter works flawlessly in both Sierra and High Sierra. Easy install of the driver via product’s website.
#37949
AR9285 Mini PCIE is working just fine on Sierra and High Sierra, installs the driver by default.
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
