by: Norton287
#33196
Kinivo BTD400 BLE Adapter, works out of box with no need for drivers supporting BLE devices.
orlandodawn liked this
#33201
TRENDnet TBW-107UB USB 1.1 Micro Bluetooth USB Adapter, And The IOGEAR GBU521 also work out of the box. Use both on my 2 hacks. Work flawless.
#34532
Ive got my hands on the Kinivo BTD400 and plugged it in. I don't have a bluetooth section in settings and its not being picked up as far as I can see. Is there a way to kickstart/reinstall bluetooth support? Im using enoch as a boot loader.
#34533
Does it show up under USB in System Report from About this Mac?
#34535
Sorry, yes. I believe so.. if its BCM20702A0. Blutooth sys info entry says no information
#34537
From terminal type with the adapter plugged in:
kextstat | grep Bluetooth
This what I have with mine:
See if you have IOBluetoothFamily.kext in System/Library/Extensions
#34538
mines looking a little different my friend :)
#34540
All the ones in mine are from IOBluetoothFamily.kext
Try loading them from a Terminal with:
sudo kextload System/Library/Extensions/BroadcomBluetoothHostControllerUSBTransport.kext
sudo kextload System/Library/Extensions/IOBluetoothHostControllerTransport.kext
sudo kextload System/Library/Extensions/IOBluetoothHostControllerUSBTransport.kext
sudo kextload System/Library/Extensions/IOBluetoothSerialManager.kext
If not install my IOBluetoothFamily.kext from 10.13.2 and try with Kext Utility:
#34542
might be getting somewhere. Im getting "failed to load - (libkern/kext) not found" for all 4 of those.
when installing HS I followed the HS official tutorial and the instructions for enoch.
I should be able to get these kexts and drop them into S/L/E? or do I need to use kext utility?
#34543
They're part of the IOBluetoothFamily.kext I attached to my previous message. Download it and install it with kext utility
I'm getting the same output from kextstat as you without the bluetooth plugged in. Try rebooting with it plugged in and see what happens.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
Good day. I have a problem - nothing happens when […]
Hi Guys. New here. I've been wanting to install OS[…]
ryzen 2400G hackintoshable ?!
Yes Is the Built-in Graphic card working?
Ryzen 2400G Hackintosh Compatible?
Integrated GPU sort of works but not properly. I[…]
AMD OS X Advertisements
